Discussion topic: ERROR MESSAGE SAYING NO NETWORK, BUT SKY CHECKS SAYING MY CONNECTION IS FINE ?
Message posted on 19 Jun 2025 12:21 PM
Message posted on 19 Jun 2025 01:42 PM
Re: ERROR MESSAGE SAYING NO NETWORK, BUT SKY CHECKS SAYING MY CONNECTION IS FINE ?
Hi @Ema0388
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router. Even if reset is not listed there is still an option to connect by WiFi to Sky or 3rd party router.
If you are on Sky Broadband with the new Sky Max router then you need to connect it as if it is a 3rd party router.
If you are on 3rd party (non Sky ) broadband then you need to enter the SSID and password for the router 2.4 Ghz WiFi band.
Message posted on 19 Jun 2025 01:44 PM
Thank you for your reply, i have done all of these steps many times, and stills says no network, but yet when i do a broadband and wifi check etc on my online account it says all checks are fine, its really strange.
Message posted on 19 Jun 2025 01:46 PM
it says there seems to be a problem with your broadband and the cross next to connection to internet, but yet all the green lights are on and i have done all the resets, and on here it says everything is fine, thinking maybe a problem with the wires or actual box itself?
Message posted on 19 Jun 2025 01:47 PM
Message posted on 19 Jun 2025 01:48 PM
not sure its all done through sky?
Message posted on 19 Jun 2025 01:50 PM
sky broadband superfast
Message posted on 19 Jun 2025 02:49 PM
