Discussion topic: Watching a live recording on Mini
This message was authored by: madaboutlotus
I have a Sky Q 2TB main box.
I am considering adding a Mini box to my Sky Q subscription. If I am recording a live program on the Sky Q main box, I can go into the live recording and watch it from the start while it is still recording. Can you do this if you access the live recording from the Mini box?
Best regards
Pete
Re: Watching a live recording on Mini
Hi @madaboutlotus
You can have up to four minis installed on loan each subject to a one off upfront charge and all under by one single Q monthly Multiscreen subscription
However only two minis can be used simultaneously on all 2 TB boxes and the 1 TB UHD Main boxes to watch Sky Q content.
The original 1 TB non UHD box (32Cxxx) only permits the use of one mini at a time.
If Sky Apps are already being used on some of the minis these will not normally be counted as in Q use and therefore can be used in addition to the above limits.
See the following link for the Versions of main Q box referred to above.
https://www.sky.com/help/articles/sky-software-updates.
Subject to the above limits Sky Q minis can be used completely independently of the main Q box and the same or different program or recording can be viewed on each Q box. Even if viewing the same content it is completely independent and can be viewed at the same or different point.
Minis can do all the features same as the main Q box and can set or delete recordings on the main Q box hard drive. There is one single storage area on the main Q box with no profiles and no indication of which Q box has set a recording. (Unlike Sky+HD Multiroom which has independent storage and planners).
It should also be remembered that minis cannot set or view UHD recordings or content.
Hi @madaboutlotus   Short answer, yes (as long as it is not a UHD programme).
Avatar for madaboutlotus
Level 2 icon
Many thanks for the explnation
Best regards
Pete
Level 2 icon
Hi MightyQuinn
Short reply, thanks :lia_slightly-smiling-face::lia_thumbs-up:
Best regards
Pete
