Discussion topic: Remote
This message was authored by: Stephen+guyett
Remote
Hi
I just need to order a new sky Q remote as on has stopped working
Re: Remote
@Stephen+guyett
If your Sky Q remote is definitely broken/faulty, if you follow this link it should allow you to do some troubleshooting and then it’ll send you to a form to request a replacement (apparently this is not available to customers in the ROI).
https://www.sky.com/help/articles/lost-stolen-damaged-sky-q-equipment#get-in-touch
It might be quicker to purchase a new one from a retailer / main supermarket. If you do that as well you’ll always have a spare.
Re: Remote
@Stephen+guyett wrote:
Hi
Hi @Stephen+guyett
If you are stuck completely without your remote if you open your Sky Go App on an Apple device you can use a virtual Q remote.
Must be iPad or iPhone.
You will find it under Settings - Devices on the Sky Go App
