2
This discussion topic has been answered Discussion topic: Remote
This message was authored by: Evans646
Remote
My remote for my multiroom box wont work ive changed batteries n everything but it wont work, but it works to turn volume up n down on my tv
This message was authored by: Laing1 Answer
Re: Remote
@Evans646 Try resetting your remote.
Press the buttons 7 & 9 together on the remote until it’s led flashes four times.
Then press 1 & 3 together until the led flashes twice then follow onscreen instructions to repair the remote.
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Re: Remote
Avatar for Evans646
Re: Remote
@Laing1 thank you so much its working again x
