Discussion topic: What needs togo back
This message was authored by: Millhouse12
Hi
Having my new box delivered as my over sky box not working .so just a replacement.
will just a q box turn up ? or are all the cables in there with the remote?
As when I pass my old box to the dpd driver with the original cables etc I don't want to find that they are not in the new box plus saves pulling All the cables out
Many thanks
Re: What needs togo back
@Millhouse12
I believe the DPD driver will place the faulty box in the box the new one was in so you should see what is included.
Remember to remove the viewing card out of your current box before the swop.
Avatar for Millhouse12
Level 0 icon
Re: What needs to go back
Thank you and aslo the reminder about the card don't want to be chasing the dpd driver down road cheers
