Discussion topic: Remote unresponsive
This message was authored by: Neilston
Remote unresponsive
Remote is only changing volume and nothing else
Re: Remote unresponsive
@Neilston Try resetting your remote.
Press the buttons 7 & 9 together on the remote until it’s led flashes four times.
Then press 1 & 3 together until the led flashes twice then follow onscreen instructions to repair the remote.
Avatar for Neilston
When pressing 1 and 3 together it flashes 20 times and no on screen instructions appear.
@Neilston try rebooting your main Q box ie
then
re-pairing your remote
if that doesn't work ypu may need a need a new remote
https://www.sky.com/help/articles/lost-stolen-damaged-sky-q-equipment#get-in-touch
