Discussion topic: Remote stopped turning TV on
Message posted on ‎19 Nov 2024 05:20 PM
All of a sudden our Sky Q has stopped turning TV on. It's never worked to turn TV off but always did to turn on. Everything else works okay.
Message posted on ‎19 Nov 2024 05:29 PM
Re: Remote stopped turning TV on
Hi @Carole141
Message posted on ‎21 Nov 2024 04:16 PM
Got up the next day and it seems to be working again. Not sure what's going on but thank you so much for your reply. Shouldn't happen again I'll try your advice.
