Discussion topic: connection
Message posted on 21 Nov 2024 03:40 PM
connection
Sky mini box continually loses connection
Message posted on 21 Nov 2024 03:48 PM
Re: connection
Hi @JON691 First try rebooting the main Q box and then when this is completely back up and running reboot the mini.
Reboot the mini as above.
Message posted on 21 Nov 2024 03:57 PM
Re: connection
Thanks @oldfella
Already have a sky booster for the sky wifi, switched it all off and still will not connect.
Message posted on 21 Nov 2024 04:09 PM
Re: connection
@JON691 wrote:
Thanks @oldfella
Hi @JON691
Assume your main Q box is connected to your router and you have the booster located between the main Q box and the mini..
Assuming the main Q box is connected correctly you need to set up the Q booster as follows.
Position the booster approx midway between the main Q box and the mini.
- Hold the WPS button on your booster for 3 seconds until it flashes amber. Then hold the WPS button on the front of your main Q box for 3 seconds until it flashes amber - You'll need to do it within 2 minutes.
- After a few minutes, the connected light on the booster should turn green. You're all set up.
Tip: Need to move your booster after you've connected, don't worry it will automatically reconnect when its moved as long as its within range of your main Q box.
Then carry out a Network Reset on the mini.
Highlight Status and then select Reset on the right hand side. Follow instructions to WPS with Q device,
You will be asked to press the WPS button on the Q booster box (not the mini as the Network reset will start the mini WPS automatically).
