Discussion topic: Remote not working
Message posted on 02 Apr 2025 06:06 PM
Remote not working
My remote is not working. It turns on tv but I have to push the button on the box to turn that on. The volume connected to sound bar works but that's all. I can switch channels or anything else.
Message posted on 02 Apr 2025 06:38 PM
Re: Remote not working
Try restarting your Sky box by switching off at the plug for 30 seconds or so.
Message posted on 02 Apr 2025 07:31 PM
Hi @Aclaire
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the remote led flashes and follow onscreen instructions to re- pair to TV or Soundbar
