Discussion topic: Sky Atlantic sky Q
Message posted on 02 Apr 2025 07:52 PM
Sky Atlantic sky Q
Am trying to watch a series on sky Atlantic and every 5 minutes it freezes and I have to turn the whole sky off and back on again. Why is this happening?
Message posted on 02 Apr 2025 08:00 PM
Re: Sky Atlantic sky Q
Hi @Claire-w-90
