This discussion topic has been answered Discussion topic: Remote not working
Message posted on 29 Mar 2023 04:16 PM
I have now had a new remote sent out and it keeps disconnecting from sky Q box now on phone to sky , I have had to do a software update , so this takes around 15 - 20 minutes so will come back and let you know if it is working
Message posted on 29 Mar 2023 04:19 PM
Hi @Mi-Mi-123
If you still have issues try try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
Hi @Mi-Mi-123
Message posted on 29 Mar 2023 05:19 PM
Re: Remote not working
Well so far so good software update has worked, they should of done this in the beginning so as I still good have had TV.
Message posted on 29 Mar 2023 10:26 PM
Thank u but all working now after soft we're updating
Message posted on 14 Oct 2023 01:15 PM
Despite replacing the batteries, the remote control unit won't allow a manual reset and new LED lights seem to be showing
