Discussion topic: Services not working
This message was authored by: Maz202384
All of a sudden some of the services have stopped working. The recordings constantly say 'Please wait' and won't load and catch up tv says 'we are having trouble reaching this service right now. Please try again later.'
I have tried resetting the box, the box is connected to the Internet and the software is the most up to date. Not sure what to do next. Any help appreciated.
Re: Services not working
@Maz202384 You could try resetting the settings in the Q boxes hidden menu.
To enter the hidden menu press the home button and scroll down to settings but do not select settings.
With settings highlighted press 0 0 1
Only Carry out the first Reset being Reset Settings as the others will wipe all recordings.
After the reset you will have to re-pair your remote assuming you are using a bluetooth remote by pressing 1 and 3 together on the remote
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Avatar for Maz202384
@Laing1 thanks for your reply. Unfortunately that didn't work and I've tried twice now. Anything else you suggest I try? Thanks
@Maz202384 I can escalate this to sky for yu if you want me to ?
@Laing1 that'd be great as it's been happening for a few days now. Thank you
@Maz202384 I have escalated this to sky for you it will be tomorrow before anything is done
You may receive an email or a private message inviting you to have a private conversation on the Community with a Sky Expert.
Look out for a chat bubble at the bottom of your screen inviting you to a chat
If you are using the Safari browser please make sure that Hide IP Address is not checked in order to see the chat bubble. If you are having trouble finding this to check the settings, use another browser such as Firefox, Chrome etc.
The link below explains how the escalation process works
This message was authored by: Addie15
Hi there! Thank you for escalating this. We have sent an invite to @Maz202384.
This message was authored by: Greenfingers001
Update:
Spoke with @Maz202384 and a Hard drive reset resolved issue
Thanks again for the escalation have a great weekend 🙂
