Discussion topic: Remote not working at all
This message was authored by: Tim80
Remote not working. Done a rest of the box and now can't turn on with remote. Tried the holding 7 and 9 but no luck
Re: Remote not working at all
Hi @Tim80
Have you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair to TV.
Failing this
Check the following link and it will lead to a form for a replacement remote.
https://www.sky.com/help/articles/lost-stolen-damaged-sky-q-equipment
In the meantime if you have an Apple device with Sky Go you can set up a virtual remote to control your Q boxes.
See following link.
https://helpforum.sky.com/t5/Sky-TV/Virtual-Sky-Q-Remote-Now-Available-on-Sky-Go/ba-p/4363637?
Avatar for Tim80
Thanks for the reply. Have tried that but when I press the 1 and 3 after tje 7 and 9 the led on the remote just continuously flashes and nothing comes up on the screen.
