Discussion topic: Remote control
Message posted on 07 Feb 2026 03:43 AM
Remote control
Message posted on 07 Feb 2026 05:17 AM
Re: Remote control
@ArshadAli
After checking the basics, ie; fresh batteries, re-pairing etc if your Sky Q remote is definitely broken or faulty, if you follow this link it should allow you to do some more troubleshooting and then it’ll send you to a form to request a replacement (I’m not sure if this is available to customers in the Republic of Ireland).
https://www.sky.com/help/articles/lost-stolen-damaged-sky-q-equipment#get-in-touch
It may be quicker to purchase a new remote from a retailer / larger supermarket. If you do that as well as the above you’ll have a spare.
In the meantime if you have an android or Apple device with Sky Go you can possibly set up a virtual remote to control your Sky Q box. See this link which may help
https://helpforum.sky.com/t5/Sky-TV/Virtual-Sky-Q-Remote-Now-Available-on-Sky-Go/ba-p/4363637?
Message posted on 16 Apr 2026 05:04 AM
Re: Remote control
Remote button is not working properly
Message posted on 16 Apr 2026 05:09 AM
Re: Remote control
Which button? If gently cleaning the remote doesn't help then see the advice in my post immediately above yours.
