2
This discussion topic has been answered Discussion topic: Remote control not working
This message was authored by: P.Shrestha
Sky Q box remote control is not working !!! I need a replacement
Re: Remote control not working
Hi @P.Shrestha
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
Is this doesn't solve your issue
Check out the following link.
Click still need help and then click get in touch after ticking the box that you have tried online help.   This will lead you to a form for free remote replacement.
https://www.sky.com/help/articles/lost-stolen-damaged-sky-q-equipment
Hi @P.Shrestha
This message was authored by: CLPearce
My remote control is not working for my pick box in the bedroom, I have replaced the batteries and checked multiple times that they are in properly - Help!!
