Discussion topic: Remote control not working on sky Q mini box
This message was authored by: gary+brandon+lee
Remote control not working on my sky Q mini box. Yvonne is on but can't get anything to work, tried everything but still won't work.
Re: Remote control not working on sky Q mini box
@gary+brandon+lee Try resetting your remote.
Press the buttons 7 & 9 together on the remote until it’s led flashes four times.
Then press 1 & 3 together until the led flashes twice then follow onscreen instructions to repair the remote.
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
This message was authored by: bob1234
Try this link for help with your Q remotes
https://www.sky.com/help/diagnostics/sky-q-remotes/what-would-you-like-help-with.
If you get to the end and decide the remote is faulty click tried everything then need more help and or contact us and you get a form to order a replacement one free.
Avatar for gary+brandon+lee
Thanks @bob1234 , tried everything you said but to no avail so I have had to order a replacement remote for the mini box. Will hopefully let you know if it works, again thanks for all your help and suggestions.
