Discussion topic: Sky Q mini box connection
This message was authored by DA2023 This message was authored by: DA2023
I have recently bought a Sky Q mini box to allow me to watch sky in a different room. I have followed the setup instructions to the letter and looked at several chats, but nothing has helped me.
my main sky Q box works fine, I can download films and connectivity is good and stable. But when I connect my Sky Q mini box using the set up it connects to the main box but then has issues connecting to the WiFi ( I do not have Sky broadband ) . When this happens my main sky Q box loses connection also and the connection between the two boxes drop.
I am wondering if it is related to poor WiFi but my other items like phone and iPad can connect at the same location as my Sky Q box mini.
any suggestions ?
Re: Sky Q mini box connection
any suggestions ?
Hi @DA2023
First off you cannot buy mini boxes as they are rented and always owned by Sky.
Assume your mini came from Sky?
This message was authored by Roadiebryan This message was authored by: Roadiebryan
I assume like me you paid a lump sum for a second mini box. Like you I have the same problem so much that the 2nd box is unusable so if you get a sensible answer I would be very interested
This message was authored by Laing1 This message was authored by: Laing1
@Roadiebryan as per the questin @oldfella asked @DA2023 did you get your mini box from Sky?
Yes, got it from sky along with the main box and another mini. Re my Wi-Fi I Garrett 350k to the boxes from virgin so broadband is not the problem
DA2023
Yes you are correct I rent the box from Sky
DA2023
From all that I have read it does seem to be an issue when not using Sky Broadband. So is there a handshake or protocol issue between the Sky Q system and the broad band when it sets up it's mesh network ?
My old system was 3 sky + boxes, my broadband was Virgin with a tplink mesh setup
when the engineer installed the q boxes he had a problem with connection so he connected them to the Wi-Fi from the Virgin modem I disconnected the tp mesh system and installed Virgin booster pods, all went well for a couple of months before the connection problems started to occur
In the last week it has got so bad the main box now loses connection and I have to reset the Wi-Fi connection which is a pain
It would seem that sky q is incompatible with Virgin
The 2nd mini box has been disconnected and unpluged from the mains, the other mini box is very rarely used so I can't say if there is any problem with that connection
