Discussion topic: Remote control not takking with box
This message was authored by: HilaryScorpio
Please can someone help
Re: Remote control not takking with box
https://www.sky.com/help/articles/sky-q-remote-help
Avatar for HilaryScorpio
Thank you. Will take a look. Trying to talk to a sky advisor on phone is just impossible.
Hi @HilaryScorpio
Have you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair to TV.
