Discussion topic: Sky Q main box stuck on software update
Message posted on 10 Jul 2024 02:39 PM
My Sky Q main box is showing "Updating software. Step 1 of 2" it has been showing this for over 1 hour. The Broadband connection is working, it appears to be stuck on this update, I have swiched the box off at the mains and put back again several times and it is still showing the same message. I would appreciate any assistance.
Message posted on 10 Jul 2024 03:23 PM
Re: Sky Q main box stuck on software update
Hi @BC41 Can you take a screenshot? It is not normal to get software update messages from Sky Q, so are you sure it is not a message from your TV?
Message posted on 10 Jul 2024 04:55 PM
Message posted on 10 Jul 2024 05:57 PM
Hi @BC41
https://www.sky.com/help/articles/sky-q-box-wont-turn-on
Also if the box you are replacing is a 2TB there are two versions of power supply. One has a standard C7 (figure of eight) power lead socket in the back of the Q box. The other has a separate power supply. Although this still has the C7 power lead into the power supply there is a multi pin Din power socket in the Q box for connecting the power supply. Make sure that the replacement box has the power supply included if the Q box has the orange coded multi pin din socket in the back of the Q box. See below.
