Discussion topic: Remote control isnt working properly
This message was authored by: Darren911
Remote conttol is not working properly
Re: Remote control isnt working properly
@Darren911
You haven't said what issue you're having but if your Sky Q remote is definitely broken/faulty, if you follow this link it should allow you to do some troubleshooting and then it’ll send you to a form to request a replacement (this is not available for customers in the ROI).
https://www.sky.com/help/articles/lost-stolen-damaged-sky-q-equipment#get-in-touch
It’s sometimes a bit quicker to purchase a new one from a retailer / main supermarket.
Hi @Darren911
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
