Discussion topic: Remote control does not operate tv
Message posted on 26 Apr 2024 07:32 PM
Remote control does not switch off or control volume up or down after a particular time. Have settings on active. Have to switch tv off at power
Message posted on 26 Apr 2024 07:35 PM
							Re: Remote control does not operate tv
Hi @Susan531
