Discussion topic: SkyQ box comes on briefly, 2 seconds, then switches off. Won't stay on.
Message posted on 26 Apr 2024 08:24 PM
Message posted on 26 Apr 2024 08:26 PM
Re: SkyQ box comes on briefly, 2 seconds, then switches off. Won't stay on.
@Sharc19 wrote:
All leads checked and good. Switched off at walk overnight. Switched on and flashes on screen for a couple of seconds then switches off. Box about 18 months old.
Hi @Sharc19
https://www.sky.com/help/articles/sky-q-box-wont-turn-on
Don’t forget to keep your viewing card from the failed box if you order a replacement. Also if the box you are replacing is a 2TB there are two versions of power supply. One has a standard C7 (figure of eight) power lead socket in the back of the Q box. The other has a separate power supply. Although this still has the C7 power lead into the power supply there is a multi pin Din power socket in the Q box for connecting the power supply. Make sure that the replacement box has the power supply included if the Q box has the orange coded multi pin din socket in the back of the Q box. See below.
Message posted on 26 Apr 2024 08:51 PM
Thank you! Tried all above and no joy. Have booked an engineer visit. Thanks again @oldfella
