Discussion topic: Remote Control Code for Blaupunkt TV
Message posted on 19 Jan 2024 12:31 PM
I have a new Blaupunkt Android TV Model BA40F4382QIB. SKy does not have a code that works with this TV. Can you suggest a correct code.
Message posted on 19 Jan 2024 12:37 PM
							Re: Remote Control Code for Blaupunkt TV
@garymce wrote:I have a new Blaupunkt Android TV Model BA40F4382QIB. SKy does not have a code that works with this TV. Can you suggest a correct code.
Some of the cheaper Blaupunkt TVs are actually manufactured by Vestel. Try going through the Vestel codes when pairing your remote.
Message posted on 19 Jan 2024 01:02 PM
Thank you, unfortunately that didnt work also. Message is Unfortunately your TV is not supported. Its a brand new TV
Message posted on 19 Jan 2024 03:09 PM
@garymce have you tried under the option of other
Message posted on 19 Jan 2024 04:23 PM
No I haven't, will try that. Thank you very much for your reply.
Message posted on 19 Jan 2024 05:08 PM
I spoke to Sky, tried everything they suggested, and the bottom line is that there are going to send me out a new Sky Q Remote Control. I will update when I receive and if it works. Again many thanks for taking the time to advise and help.
