2
This discussion topic has been answered Discussion topic: Remor note connecting to box properly
This message was authored by: Farmer1960
Remote not connecting properly to box, changed remote issue still the same
Re: Remor note connecting to box properly
Hi @Farmer1960
First reboot your Q box.
Hi @Farmer1960
Avatar for Farmer1960
Thanks very much it has worked.
