7
This discussion topic has been answered Discussion topic: Red button S4C
This message was authored by: Sammyd83
Red button S4C
Red button doesn't work on S4C to get English commentary on sports - despite the program specifically saying "press red button for English commentary"
I reported this last year and got palmed off
This message was authored by: nigea99 Answer
Re: Red button S4C
hi @Sammyd83
I don't know about the red button but when there is English Commentary on S4C you should be able to get it by having done this:
Go to
Home -Setup -  Settings - Preferences
Scroll down to language & select Welsh
Yes I did say Welsh (to get the English Commentary! - no idea why it works counter intuitively)
Re: Red button S4C
hi @Sammyd83
Go to
This message was authored by: Raider999
Re: Red button S4C
@nigea99 thanks for posting this - recently watched the Wales play-off games on S4C in Welsh - thought you used to be able to get English commentary via red button but it wouldn't work.
Need to keep note of this for future reference,.
Re: Red button S4C
@Raider999 once set you should get the English Commentary (or on any similar dual language show) when available without making additional changes
Re: Red button S4C
@nigea99 would this apply to recordings or only live viewing?
Re: Red button S4C
hi @Raider999
I will be honest & say I don't know.
My guess is that it will work with a recording from the live channel as I think it is likely to record both audio channels - the setting should work when there are multiple audio channels
I also suspect that if there are downloads available these may only have a single audio channel
This message was authored by: robertkam
Re: Red button S4C
It is home  - settings - set up - preferences. It works!
This message was authored by: mrsjwr
Re: Red button S4C
Great thanks for the info x that worked and can now listen to the match in English
