Discussion topic: Having broadband problems with my sky q mini boxes in multirooms electricity disruption a week ago a
Message posted on 05 May 2024 04:52 PM
Problem with sky q mini boxes in multi rooms !broadband only connects intermittently so tvs on and off the furthest room away is the worst so I thought broadband speed was slow but my provider assures me its fine and thinks I need sky booster directly into minibus!this problem started after we had a power cut !any help welcomed please
Message posted on 05 May 2024 05:00 PM - last edited: 05 May 2024 05:01 PM
Re: Having broadband problems with my sky q mini boxes in multirooms electricity disruption a week a
Reboot the minis as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you get the first mini connected then for other minis use WPS on the nearest Q device (main Q box or Sky Router if on Sky Broadband or previously connected mini).
Failing all of the above you may need a Sky Q WiFi Booster to position midway between your main Q box and the minis and you will need to contact Sky directly.
Message posted on 05 May 2024 05:26 PM
@Bartholomew1951 wrote:Problem with sky q mini boxes in multi rooms !broadband only connects intermittently so tvs on and off the furthest room away is the worst so I thought broadband speed was slow but my provider assures me its fine and thinks I need sky booster directly into minibus!this problem started after we had a power cut !any help welcomed please
Who is your broadband provider?
