Discussion topic: Sky Q Box keeps turning off
Message posted on 04 May 2024 04:12 PM
Sky Q box keeps turning off.
Sometimes it will be after 30 minutes or so. Other time it may be only 10 minutes.
It doesn't appear to be overheating.
I've done a basic reset and it's still happening.
Message posted on 04 May 2024 04:49 PM
Re: Sky Q Box keeps turning off
Was it a Reset Settings in the hidden menu @daveoto ?
Message posted on 04 May 2024 05:18 PM
Yes. It was the (hidden) reset.
Message posted on 04 May 2024 06:33 PM
Message posted on 05 May 2024 02:30 PM
Will I then lose all my recordings?
Message posted on 05 May 2024 06:09 PM
@daveoto afraid so but if you need a replacement box you would lose you recordings anyway.
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
