Discussion topic: Recurring Sky Q advertising
Message posted on 09 Jun 2023 08:14 PM
Any help here is much appreciated.
Turning on my Sky Q box, all I get is the Sky Q advertising and it keeps on cycling. There is no way to get out of it as, none of the buttons seem to work aside volume and few others. I did do the upgrade but, issue persisted.
I did contact Sky and the chap I spoke to suggested I change the box, which I did....guess what....the problem is still ongoing.
Any help?
Message posted on 09 Jun 2023 08:28 PM
Re: Recurring Sky Q advertising
Any help?
Hi @Aji1999
Try a reboot as follows.
If the remote didn't turn on the Q box
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
Message posted on 09 Jun 2023 08:53 PM
Thanks.
I have been on to Sky and it's now sorted.
You might be onto something there. Despite restarting the box like a hundred times, the difference this time might have been pressing 1+3 or 7+9.
