Discussion topic: Mt skyq box is not working
This message was authored by: Jessicarebeca
It says is not connection
I have tried to go to settings than connecting the router than it says to pres on WPS button to connect but still not working I have tried to plug the wire again in to the router still not working
Re: Mt skyq box is not working
Hi @Jessicarebeca
Assume you carried out a Network reset on your Q box.
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router.
