Discussion topic: Recordings
Message posted on 14 May 2024 09:30 AM
Recordings
My recordings keep freezing I have tried switching off from the mains, but it works for a while then starts again.The box makes the sound like when it is restarting
Message posted on 14 May 2024 10:04 AM
Re: Recordings
Hi @Mar_
