Discussion topic: Recordings
Message posted on 04 Feb 2024 02:02 PM
Recordings
My recordings will not load. It just says please wait. I have tried rebooting several times, tried unplugging altogether, and even gone through the resetting procedure. My tv programmes all work fine, my tv schedule comes up and my Home Screen shows all the top picks etc.
Message posted on 04 Feb 2024 02:20 PM
Re: Recordings
This will be an odd question.
What happens if you try to pause live tv?
ROI sky Q Customer.
Message posted on 04 Feb 2024 02:23 PM
Re: Recordings
It will not pause or rewind
Message posted on 04 Feb 2024 02:33 PM
Re: Recordings
When I try to pause it a message comes up saying this service is not available because of a problem with your hard disc drive!
Message posted on 04 Feb 2024 03:00 PM
Re: Recordings
@LisaG2904 wrote:When I try to pause it a message comes up saying this service is not available because of a problem with your hard disc drive!
That was what I was worried about.
I had the same issue last August.
I did a manual reset of the hard drive (which will lose the recordings)
Unfortunately for me, the problem (and other problems) recurred after it and I had to get a replacement sky q box.
ROI sky Q Customer.
Message posted on 04 Feb 2024 03:21 PM
Re: Recordings
Ok thank you for your help.
Message posted on 04 Feb 2024 04:57 PM
Re: Recordings
@LisaG2904 try following the link below if you try everything in the link it will eventually lead you to a link to request a new box
https://www.sky.com/help/articles/sky-q-hard-disk-error-messages
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 04 Feb 2024 07:34 PM
Re: Recordings
Thank you. I followed the link and this time instead of just doing the basic reset I reset the hard drive. This appears to have worked. Yes I've lost all my recordings but I couldn't access them anyway. I can now pause and rewind etc and record and download again. Let's hope it lasts. Thank you both for all your help.
Message posted on 15 Sep 2024 05:39 PM
Re: Recordings
Recordings not working. Just says wait. ! Just going round and round.
