Discussion topic: Sky box and mini box no internet connection
This message was authored by: Mellor21
y sky box is saying I have no internet connection
I've tried all the recommended actions and it will not connect
Re: Sky box and mini box no internet connection
Hi @Mellor21
Wait until the router is completely back and running and then try a Network Reset found in main Q box Home - Settings - Setup - Network.
