Discussion topic: Wall mounted tv, cable too short
Message posted on 15 Sep 2024 03:52 PM
Just wall mounted TV. Cable from dish not l9ng enough to 'trunk' would an engineer have to come and fit a new l9nger cable? Is there a charge for this
Message posted on 15 Sep 2024 04:08 PM
Re: Wall mounted tv, cable too short
Sky would likely charge £65.
...or just use extension cables, widely available, e.g. Amazon
Message posted on 15 Sep 2024 04:14 PM
hi @JW74
If it is the lead from the dish that needs extending you maybe better just buying a Sateliite extension cable (available in various lengths) from various sources than paying SKY to replace the cable with a longer one - they don't usually do any specialised work.
If it is the lead from the box to the TV, you can get HDMI lead, again in various lengths, from online sources - just ne careful with the length for 4K use.
4K needs HDMI 2.0 although 2.1 (8K) are now available at decent prices & may allow longer length to be used for 4K
