Discussion topic: Recordings won’t load
Message posted on 21 Mar 2024 06:38 PM
Hi
my sky q box won't show my recordings , I go to recordings in menu and it just says please wait and buffers
ive unplugged box, reset router nothing🤷♂️ Tia
ryan
Message posted on 21 Mar 2024 08:04 PM - last edited: 21 Mar 2024 08:05 PM
Re: Recordings won’t load
@Vale41 wrote:
Hi
ryan
Hi @Vale41
If also cannot make new recordings Work through the following link
https://www.sky.com/help/articles/sky-q-hard-disk-error-messages
Don’t forget to keep your viewing card from the failed box if you order a replacement. Also if the box you are replacing is a 2TB there are two versions of power supply. One has a standard C7 (figure of eight) power lead socket in the back of the Q box. The other has a separate power supply. Although this still has the C7 power lead into the power supply there is a multi pin Din power socket in the Q box for connecting the power supply. Make sure that the replacement box has the power supply included if the Q box has the orange coded multi pin din socket in the back of the Q box. See below.
