Discussion topic: Recordings saved to ‘other’
Message posted on 30 May 2023 10:22 AM
Hi,
can anyone explain to me why recordings on a series link are recorded as 'other' whilst some are just in the normal series if that makes sense?
Message posted on 30 May 2023 10:24 AM
Re: Recordings saved to ‘other’
@Helenkaney wrote:
Hi,
Hi @Helenkaney
Does sometimes happen without any known reason.
Probably just glitches
Message posted on 30 May 2023 10:34 AM
More than likely part of the stacking issue mentioned in this thread
https://helpforum.sky.com/t5/Sky-Q/Non-Stacking-of-Recordings-Better-but-not-solved/td-p/4195719
if it's only just affecting you now you're quite lucky.
