Discussion topic: Recordings not working
Message posted on 08 Aug 2025 09:29 AM
I am trying to play my recordings but every time I play one it comes up there is a fault on channel
Try again later ?
Message posted on 08 Aug 2025 09:44 AM
Re: Recordings not working
Try again later ?
Hi @Kerry173
Assume you have tried rebooting your Q box?
Failing this
