Discussion topic: Recordings not showing/loading
This message was authored by: Moonstone14
Just turned q box on but recordings not loading. Tried a restart but still not happening.
Re: Recordings not showing/loading
@Moonstone14
There are issues this morning with Sky Glass but I've just tried my Sky Q and it's fine. By restart do you mean a reboot?
Try a reboot of the main Sky Q box, then once that’s back up and running do the same with any mini boxes if applicable -
~ press the 🏠 button
Allow 5-10 minutes before things hopefully revert back to normal.
