5
This discussion topic has been answered Discussion topic: Tv not playing
This message was authored by: ColetteMcC
Tv not playing
Internet on. Good signal. Can get sky homepage but nothing will come on when selected....no live TV recordings or apps
Whats the problem and how is it fixed?
Re: Tv not playing
Hi @ColetteMcC
First try rebooting your Q box?
If the remote did not turn the q box on,
Re: Tv not playing
Hi @ColetteMcC
Avatar for ColetteMcC
Re: Tv not playing
Thanks a million. All sorted
Re: Tv not playing
Sorted thanks
This message was authored by: Dolly20
Re: Tv not playing
Blue screen each time I try to use my tv including apps this morning. I have tried to reboot but the screen is still blue.
Re: Tv not playing
@Dolly20
Is this definitely on Sky Q, as there are Sky Glass issues this morning?
