Discussion topic: Recordings have disappeared
Message posted on 07 Nov 2024 08:56 PM
Had problem with sky q
rang. And you talked me through re booting
now all my recordings have gone !!
Message posted on 07 Nov 2024 09:02 PM
Re: Recordings have disappeared
@xxxx1
You aren’t contacting Sky by posting on here. We are mainly customers trying to help other customers.
A simple reboot as I've described below should NOT make recordings disappear.
~ press the 🏠 button
Message posted on 07 Nov 2024 09:03 PM
Then why was this the link that sky sent me
Message posted on 07 Nov 2024 09:05 PM
What link? To go to the forum?
Message posted on 07 Nov 2024 09:11 PM
recordings will only disappear if you delete them or reset the hard disk (or if the hard disk has failed).
