Discussion topic: Recordings have disappeared
This message was authored by: xxxx1
Had problem with sky q
rang. And you talked me through re booting
now all my recordings have gone !!
Re: Recordings have disappeared
@xxxx1
You aren’t contacting Sky by posting on here. We are mainly customers trying to help other customers.
A simple reboot as I've described below should NOT make recordings disappear.
~ press the 🏠 button
Avatar for xxxx1
Then why was this the link that sky sent me
@xxxx1
What link? To go to the forum?
recordings will only disappear if you delete them or reset the hard disk (or if the hard disk has failed).
