Discussion topic: Recording
Recording
Can't record, states disc full. Manage shows % not set
This message was authored by: Stephen+Mourton
Re: Recording
This is the obvious try, so you may have done it, but if not switch off the power to your Sky box either at the switch or by removing the power lead from the back.  Wait at least 30 seconds and turn back on.  Wait for it to all fully load which can be several minutes then check and see if that sorts it.   I hope it works.
Re: Recording
Tried that a number of times, can open up tv menu and change channels but can not see any recordings or record
Re: Recording
Hi @Anonymous
If you can get into the Settings menu on your Q box
