Discussion topic: Recording playback issues and lots of lag….
Message posted on 18 Sep 2025 10:07 PM
For the last two weeks changing channels or trying to play recordings is accompanied by a good 15-20 seconds lag. Similarly I can't pause TV or rewind/fast forward a show without a long preceding pause then abrupt jumps. All reports on diagnostics as ok.
Is this the after-effects of a recent software update, although I've tried about 6 restarts (and had a recent power cut for a full reset!) to no effect.... Or is this the onset of a hard disk fault? (Cue request for new box....)
Anything else to try?
Message posted on 18 Sep 2025 10:11 PM
Re: Recording playback issues and lots of lag….
Hi @MLancaster
Message posted on 19 Sep 2025 03:37 PM
I'm afraid that didn't help. I guess next to try is a next level reset with the loss of all recordings?
