Discussion topic: Recording fails for some programmes
This message was authored by: NitinVK
recording fail's repeatedly
Re: Recording fails for some programmes
@NitinVK
Have you tried rebooting the main Sky Q box?
Avatar for NitinVK
I did it once whilst on phone with sky support. No difference
@NitinVK
So what did the agent then suggest or arrange? Box swap maybe?
Avatar for NitinVK
@Daniel0210 the support told me to reset and see if it solves The issue. Clearly, it hasnt
@NitinVK
Call them back, explain that and see what they recommend. Possibly a doorstep box swap, in which case remember to remove your viewing card from the box before handing it to DPD.
Avatar for NitinVK
@Daniel0210
thank you. I spoke to support and did the same few steps
