Discussion topic: Recording fails for some programmes
Message posted on 30 Sep 2023 01:00 PM
recording fail's repeatedly
Message posted on 30 Sep 2023 01:10 PM
Re: Recording fails for some programmes
Have you tried rebooting the main Sky Q box?
Message posted on 30 Sep 2023 01:12 PM
I did it once whilst on phone with sky support. No difference
Message posted on 30 Sep 2023 01:13 PM
So what did the agent then suggest or arrange? Box swap maybe?
Message posted on 30 Sep 2023 01:18 PM
@Daniel0210 the support told me to reset and see if it solves The issue. Clearly, it hasnt
Message posted on 30 Sep 2023 01:20 PM
Call them back, explain that and see what they recommend. Possibly a doorstep box swap, in which case remember to remove your viewing card from the box before handing it to DPD.
Message posted on 30 Sep 2023 02:38 PM
thank you. I spoke to support and did the same few steps
