Discussion topic: Recording does not work
Message posted on 11 Apr 2024 02:34 PM
I went on holiday and turned my sky off at the wall was off for a week,I have returned home turned it on and my recording does not record or my catch up does not work
Message posted on 11 Apr 2024 03:06 PM
							Re: Recording does not work
Hi @Maria74
When the router is completely back and running reboot the main Q box.
When the main Q box is back up and running try a Network Reset found in Q box Home - Settings - Setup - Network.
