Discussion topic: When I go into my recorded settings to watch programs I’ve recorded it say unavailable
Message posted on 11 Apr 2024 03:15 PM
I cannot watch my recorded programs it say this surface is unavailable
Message posted on 11 Apr 2024 03:20 PM
Re: When I go into my recorded settings to watch programs I’ve recorded it say unavailable
@Gail27 Have you tried rebooting your main Q box ie
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 11 Apr 2024 03:31 PM
Hi @Gail27
If you also cannot make new recordings then you may have a hard drive issue.
https://www.sky.com/help/articles/sky-q-hard-disk-error-messages
Don’t forget to keep your viewing card from the failed box if you order a replacement. Also if the box you are replacing is a 2TB there are two versions of power supply. One has a standard C7 (figure of eight) power lead socket in the back of the Q box. The other has a separate power supply. Although this still has the C7 power lead into the power supply there is a multi pin Din power socket in the Q box for connecting the power supply. Make sure that the replacement box has the power supply included if the Q box has the orange coded multi pin din socket in the back of the Q box. See below.
