Discussion topic: Recording connectivity issues
Message posted on 09 Apr 2025 04:32 PM
Our Sky Q Box is a few years old. Just lately we are getting a number of recordings which lost picture citing connectivity issues which then have to be fast forwarded past.
is this likely to be the hard drive getting overused and is there a fix or does it need replacing?
Message posted on 09 Apr 2025 04:40 PM
Re: Recording connectivity issues
Hi @Cookie43
Try a Reset Settings in the Q box hidden menu. See if that helps.
