Discussion topic: How long does it take for your apps to reappear on screen when you have a new sky q box
This message was authored by: Nickbuick
I have just installed a new sky q box and my app links have disappeared. Why? My previous sky q box was losing Internet connection on a daily basis.
Re: How long does it take for your apps to reappear on screen when you have a new sky q box
Hi @Nickbuick
First make sure that the Q box is fully connected to your Network.
If you are on Sky Broadband you will be asked to press the WPS button on the Sky router. (Not on the Q box as the Network reset will start the main Q box WPS automatically). Make sure you press the WPS button on the Sky router and not the reset button.  If you are on Sky broadband with the Sky Max hub then you need to treat this as a 3rd party router
If you still have no Apps
Have you tried refreshing the Apps in the Hidden menu.
Select Apps 
then highlight Refresh all Apps on this box.
You'll see a message that says, 'Your apps are being refreshed'. This will stay on screen until you press Dismiss to return to normal viewing
It’s recommended waiting at least 5 minutes before doing so.
Refresh Apps can take up to 24 hrs to complete .
