Discussion topic: Recorded
Message posted on 18 Feb 2024 07:49 PM
Recorded
Hi. I can't seem to play my recorded programs. It just shows a blue screen
Message posted on 18 Feb 2024 07:57 PM
Re: Recorded
Hi @Rajka1
First try rebooting your Q box.
If you still have the same issue and also find you cannot make new recordings work through the following link
https://www.sky.com/help/articles/sky-q-hard-disk-error-messages
Ordering a new Q box usually means a doorstep swap.
