Discussion topic: Connecting sky q box and tv to router directional arrows?
This message was authored by Kaya2 This message was authored by: Kaya2
Hi Community
We are connecting sky q box and tv to router.
Can you tell us which way the directional arrows should go please?
Re: Connecting sky q box and tv to router directional arrows?
@Kaya2 wrote:
Hi Community
Hi @Kaya2
To which directional arrows are you referring??
Sky Q box connects by HDMI cable to TV set.
HDMI leads can go either way round.  If using the Sky HDMI cable with one pink end this is colour coded to go into the Q box.   However it can go either  way.
Connection between Sky Q Box and Router is normally by WiFi. This is achieved by carrying out a Network reset on the Q box.
